Problem using CPT and categories
Hello all. I have a problem and can’t find any solution in the forum. I’ve created a CPT named “products”. I use the usual categories for this CPT.
For exemple i’vd created a category named “lingerie” for use with the CPT.
And my problem is if i want to display the category page for lingerie. There is no content, the CPT is not on the page.
I tried to use the CPt with taxonomies but i have the same problems. The template seems to don’t know how to display the custom post types.
Hello reunionssecretes,
Unfortunately our theme was not designed to support custom post types in it’s modules and blocks. In order to achieve this you will have to modify the theme’s code. If you want to do this we unfortunately cannot offer any custom work at the moment, as we work hard on the development, updates, fixes and support. You can always get a freelancer from sites like: http://studio.envato.com/andwe
