Hi There
When I change post pagination buttons’s style by a plugin ,I got this problem in the link bellow ,I need the pagination to be at the bottom of the post up sharing buttons’s line,And by the way the plugin works good in other wordpress themes there is also an example,
The problem :
Working example :
Hello AnasTfx,
Unfortunately, I do not know what kind of plugin you are using for this changing and also, please notice that we do not recommend using something like this because you can encounter some problems. Notice that we cannot provide support for untested plugins.
Hello AnasTfx,
Please notice that our theme does not have any such an option that allows you to change the post pagination, sorry! If you are referring to the post pagination when you have a smart list if you want to change the pagination from that templates you should switch to another smart list template. Our theme has only number pagination for latest articles and arrow pagination for blocks. If you want to change them to another style of pagination, you should edit yourself the theme’s code with you want and also, if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
