Problem when editing and saving
As I am changing items on the page and saving the system does not save it correctly. Block titles and content either gets corrupted or goes back to a default state. Blocks are changing position… Very strange!
Please advise!
Also please check your memory allocation and make sure these parameters are set properly: https://forum.tagdiv.com/system-status-parameters-guide/
