Problem when pages/post is loading
Hi tagdiv team,
I have a little Problem when my pages/post are loading…
Before loading, it show me all my menu link. Tell me please how can i solve it.
This is a print screen that what im talking about
http://www.elversiculodeldia.com/wp-content/uploads/2014/12/pages-uploading.png
Thanks in avance.
Braulio
Dominican Republic
This is usually from a slow connection where the CSS is loading too slowly. Some CDN/caching settings can cause that, and sometimes the tagdiv speed booster plugin.
This could also be due to the speed booster plugin version 3.0 that was provided with the latest theme version, which is 4.6 (by mistake we have added 4.5d).
Other than this css flash which appears only when using the speed booster plugin the theme should work fine so please make sure that you empty all cache the purge files if you use any CDN host service then disable all plugins and check again.
Hope this helps! Please let me know!
Thanks for your response.
I think is not a slow connection, i have been testing in slow and faster connection and is all the same thing.
Im not using CDN / Caching plugin at this moment.
I was using Total Cache plugin before install this theme. I was looking in wp-config.php file and I deleted these lines:
/** Enable W3 Total Cache Edge Mode */
//define(‘WP_CACHE’, true); //Added by WP-Cache Manager
define(‘W3TC_EDGE_MODE’, true); // Added by W3 Total Cache
I disabled the speedbooster plugin and now the pages/post are loading fine: http://www.elversiculodeldia.com/ it is not showing me the links before showed. but pagespeed score now is lower.
Any suggestion?
By slow connection, I actually meant the server was not serving up the information as fast as the browser can take it in. So what happens is that things don’t load in correct order sometimes. If your server response time is more than .05 or .10 seconds this can happen, based on my own experience with using the speed booster plugin. (Ours is .031 seconds so we don’t see this issue.)
This may have nothing to do with your particular case.
  • This reply was modified 11 years by simchris.
Not using the speed booster plugin does slow the site as it’s purpose it is to speed it up so you can use the previous version of the speed booster plugin which works fine until the next theme update in which we will fix this issues.
If you don’t have the 2.5 version of the plugin you can send an email at contact@tagdiv.com and make a request for it and we will send it to you.
Hey Lucian, my site Elite Envy is doing this too. You said in the next version speedbooster should correct this issue? Looking forward to it. Thanks!
Until we release the next theme update you can send us an email at contact@tagdiv.com with a request for the previous version of the plugin and we will send it to you.
Sorry for the inconvenience and thanks for the message!
I received the 2.5 plugin version and now is working fine.
I will waiting for the next update version.
