Problem when scroll down sidebar
I have a problem with a sidebar
When i scroll down see this
http://imagebin.ca/v/2Zt8wXjEmFw4
If i scroll up return ok
http://imagebin.ca/v/2Zt98ifiYqak
Why?
Hello pasqualino77,
I have checked your website and I saw your problem with the sidebar. I suspect this issue that comes from your untested plugins which you are using and which create some interference between our theme and this kind of plugin. Please try to disable all the active plugins, leave just Visual Composer active, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins. Always, when you have some errors/issues/bugs in the theme, please compare your site with the demo version and check if its are found in our demo. If these are found in demo means that is a real problem in the theme, otherwise the issue only comes from your side (customization, plugins, etc).
Thank you for the message!
ok .. now try a fresh installation
