Hello
I have used your theme here (https://charming-bose.176-9-28-118.plesk.page/) but when I try to apply a category or post template the layout breaks. In preview everything seems fine but when I apply the template the category or post seems broken. An example can be found here (https://charming-bose.176-9-28-118.plesk.page/category/empeiries/) where I have applied ‘Category template – Makeupshop’ yet the posts seem to extend to the whole layout and push down the sidebar. This applies with every template I try to implement for categories and posts.
Can you send us a screenshot from the tagDiv Composer? Something similar to this: https://www.screencast.com/t/1HZZNmgXN
I want to see how your elements are arranged.
Here is a screenshot of the category template
https://www.screencast.com/t/P9BLowmQ
However in real time when I implement it it looks like this
https://charming-bose.176-9-28-118.plesk.page/category/iatrika-themata/
Hi gkalaitzis, the website it looks like that because you have a plugin conflict, I see that you have enable the WPBakery plugin, and this is interfering with tagDiv Cloud Library (cloud templates), we recommend to use only one of theme and disable the other one. Since you are using a pro demo, all the templates that you are using are from cloud, therefore, I recommend to disable the WPBakery plugin and everything will look normal.
