Hi TagDiv Team!
The problem is really easy to see, check my site please: http://desarrollotrazos.ucse.edu.ar/index.php/articulos-con-referato/
As you can see, under the articles there’s a LOAD MORE button but when you click it the block images just doesn’t load.
AFAIK it should be working that… did i miss something? could you guys tell me how can i get it work?
Unfortunately I could not access your website: http://screencast.com/t/Ksi3nHvKfeM8
This type of errors usually occur from plugin conflicts. Please disable all your plugin except visual composer, clear cache and reset cdn files if you use it. If the problem gets resolved when you do this, it means that one of your plugins is not compatible with the theme.
Let us know how it goes.
Sorry again, upthere it’s me with another account/license.
Well anyway the new address is revistatrazos.ucse.edu.ar
Please go ahead and check this: Under the articles there’s a LOAD MORE button but when you click it the block images just doesn’t load.
Any idea why?
I have checked your website bu the load more button seems to be working properly. You can see it in this video: http://screencast.com/t/daJncXHX
Sorry but that’s not the problem Bogdan.
Check the following link and go down to the bottom:
If you click then “LOAD MORE”, block images looks missing: href=”https://k61.kn3.net/5/0/C/8/3/6/129.png” target=”_blank”>
OK.
I have found the page with the issue. Are you sure you have a featured image set to those posts? as the placeholder seems to display instead. If you do have featured images set, please try to disable all your plugins except visual composer, clear cache and reset cdn files. If the problem is still there afterwards, please send us an email at contact@tagdiv.com and provide wp-admin so we can take a look. Also include a link to this topic so we can identify you.
thanks.
