Problem While adding posts
We are not able to select the author while adding posts. It is unclickable. Also screen option on upper side is also unclickable. Are you upgrading the theme
Try to deactivate all plugins except Visual Composer, clear all caches than test again. Also make sure that you’re using last theme version available on themforest, V 2.3.6, and also update Visual Composer at v 4.11.2. Here you can find our documentation for more details about update process: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/
Let us know how it goes and if the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
Thank you for the solution. One of the plugin deactivated and problem got solved
