my website is http://www.portaldorugby.com.br
last friday I was trying to change one AD picture inside NEWSPAPER THEME configuration. I dont know why but my changes was not saving.
So I loged in direclty into the mysql database and found the line I want to change.
It was in table wp_options, option_id 67652 . So I changed in the command line.
WHen I saved, everything in my website had a problem. I lost all theme configuration.
But now I dont know how to replace the original code inside mysql. The id_option doesnt exist anymore.
I have the original option_value, but the option_id 67652 dosnt exist anymore. How can a replace the current configuration to the old ?
I dont have backup files =/
thanks
Pedro Mantovani
If you do not have backup, I believe there is no way of reverting the changes made to the database. Maybe the hosting could have an automated backup system, you could check that.
It is highly recommended to make periodic backups to the website, in case of problems. The theme panel settings can also be exported using this theme feature
– https://forum.tagdiv.com/import-export-theme-settings/
Simion, tks for your help.
I had rebuid the home page. It was easier than I thought. The visual composer helped me a lot.
