problem whit cusomizing newspapare theme
hi
i am using newspaper them. i import an demo
put it is not working properly,
especialy video part. and editing sidpar
you can see that in piturevideo playe part
left part issu
Do you maybe use RTL? The theme design will most likely not look properly if RTL is used. The theme does not support RTL unfortunately. It would require many modifications to make it compatible and display better in these circumstances. Sorry for the inconvenience.
