Problem whit visual composer
Hi, i have a problem whit visual composer, When I want to edit a page appears as shown and never finishes loading.
http://es.tinypic.com/view.php?pic=vskphx&s=8#.VOgPMPmG-So
thank
I find Chrome works better than IE or Firefox, myself. I also find sometimes I have to “save” the page when it starts to go into a circle of nothing happening. Then next thing I do will work; almost like there is an Ajax buffer which can only handle so much at once, then it just doesn’t do anything.
I’ve found it’s also useful to clear the temp files in my browser, if I haven’t done that in awhile.
Thanks Chris ! I solved it by deleting and reinstalling the plugin.
🙂 That was the more obvious option. Glad it’s working!
