Problem wit adding woocomerce shop page
Hello i instal woocomerce and when i want to add it with tagdiv composer i get this error Error at rows: 1(models) : 0(dom). The model does not match the content is there any DEMO that i can upload also for SHOP woocomerce.
You can design a page with the tagDiv composer, display products in it with shortcodes for example (shortcodes can be entered in text elements)
– https://docs.woocommerce.com/document/woocommerce-shortcodes/
Then set this page as shop page in Woocommerce settings. An important note is that after you set this page as shop page, if you try to edit it again with the composer there may be an error.
Maybe that is what is happening for you. Editing the set shop page may result in an error.
But how i can make page like this it cant been done with this shorcodes https://demo.tagdiv.com/newspaper_tech/shop/
That page isn’t hard to make with Newsmag as well. It consists of a single image element at the top, then a column text. The next two sections are made with Woocommerce shortcodes, for example
– https://www.screencast.com/t/liO6o09Px
– https://www.screencast.com/t/qCg9WJSBmYQH
The section at the bottom (product loop) will appear after the page is set as shop page
– https://www.screencast.com/t/ySV3nyI16p
– https://www.screencast.com/t/XHHPrJeMelig
