problem with
HI!! I`m trying to show time at home but it’s impossible for me. I can see the date, but not the time. What can I do?? Thanks!!
I’m not sure what you mean? Do you want the current date in the top menu like here: http://screencast.com/t/KG1G4cmicMww
Go to Theme Panel -> Header and there open the Top menu section and enable the Show date option http://screencast.com/t/HqADpGic39q
hI!! Not really, I’d like to show the creation time of each post to show it beside the date of the post, at home page.
Thanks!!
this is standard WordPress functionality, you can change the date and time format from here: http://screencast.com/t/l1Hsa1fgcFvW
I’ve entered this to add the time in the format like “19:32” . You can also change the format as you like using this: http://php.net/manual/en/function.date.php
M j, Y - G:i
Hi!! Thkas a lot but this do not solve my problem. For example, I can read at the code of td_module_1.php this string: <?php echo $this->get_date();?>
In other wordpress projets I usually can read <?php the_time(‘F – j – Y’); ?> <?php the_time() ?>
But with Newsmag this doesn’t work.
I’d like to show the date and the time when the post was write.
I’m lost…what can I do??
Thanks!!
the main function that show the time for all modules is here:
/includes/wp_booster/td_module.php
http://screencast.com/t/KJKCcElcI
the theme is using this function from WordPress to show the time: https://codex.wordpress.org/Function_Reference/get_the_time
But the solution from my previous reply works, I’ve tested it: http://screencast.com/t/XRdHBbeKV (it’s with a 24 hour format but it’s easy to change to a AM/PM one)
