I have a problem with the 2e level menu on the right side of the theme Newspaper. Juste a part of the main menu appaeared of the border of the fix frame (on a 27inch screen) Do you have a solution?
Thank for your Theme and your help
Jacques G.
You can see on my site or on the screenshot link here:
http://www.ecdqorg.info/
Hello WebECDQ,
Please try the code below and add it in Theme panel->Custom CSS area.
The code is ->
@media(min-width: 768px){
.td-boxed-layout #td-outer-wrap {
overflow: initial !important;
.td-mobile-nav-wrap {
display: none;
The result you should see here -> http://screencast.com/t/G6kXKDvgGXWe
I have added this BUG on our list of fixes and we will resolve this in our new feature updates.
Thank you for your message and sorry for the inconvenience!
