Problem with 4.7 and Newspaper? Slow site
I updated wordpress to 4.7 and from that time my site became slow, it started generating 503 errors and server resources were raised.
I disabled all the plugins and the problem continues, the only option I have left is the theme.
Any ideas?
The only thing I updated immediately before the problem, was wordpress to 4.7
Regards, Mariano
I had to go through and restart the upgrade due to a get_user_locale error. The upgrade database notice finally showed the second time. Have you tried a reinstall? Were you presented the first time with the db upgrade notice?
Please check the errorlog and see maybe you can find some references there. We have tested the theme with wordpress 4.7, also with beta version and we did not found any issue. We will do more test as we prepare a new release, most probably next week if everything is fine.
Hi, I’m noticing the same slowness with WP 4.7 and also had issues upgrading initially. The front-end of my site seems normal but the admin section is like a turtle now.
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
