Problem with a link from sidebar ad
Hi guys,
I have a problem with link from sidebar ad.
I created sidebar ad with my custom image in the theme panel – sidebar. Then I option my widget, choose “Use ads spot from sidebar” and put url address to place “Title URL”. But the link is not working.
Could you help me please?
Tomas
It should work properly if you have set it right. For example an image with a custom link in the sidebar ad section
– https://www.screencast.com/t/z8DYJ2xz
Then place an Ad box element on the page and select the sidebar spot
– https://www.screencast.com/t/uvvJzhbMIW8
The image will direct to the link you have set in the ad code
– https://www.screencast.com/t/lDpcFrrxRx
The title URL will work if the element has a custom title, and only when the title is clicked
– https://www.screencast.com/t/pNou2HkLCa6
Please correct me if I misunderstood the problem.
Hi Simion,
thank you very much. Finally it is working 🙂
It was a my mistake. I had the bad code in the ad element.
Tomas
