I have problem with activation of the theme. I get virus on site and gets DDOS attack and I need to delete site and make it again. My webmaster blocked site in the firewall for the attacks. But now I cant activate site probably RestAPI blocked. Can you get advice how to whitelists TagDiv domain for possibilty of activation.
Thank you Jan
You need to ask your host about it to help you.
Please let me know what version of the theme you use.
If an attacker wants to target this URL /wp-json/tdw/save_css they can do so. Even if the website uses a different theme, the attacker can still try that URL. We could add an option to be able to enable/disable the Live CSS, it will be considered. But for now in order to remove it this can only be done with a modification to the composer plugin. I think that all that removing it requires is to comment this line of code – https://prnt.sc/RtwvL5Nc4ikR -> https://prnt.sc/ymZmhdUfp57U But as I mentioned, the attacker can still try to access the URL.
Please set this one in the whitelist https://xczech.com/wp-admin/admin-ajax.php?td_theme_name=Newspaper&v=12.6.3 and try after.
