Problem with Ad
I need help please
When I try to add an Adsense ad
I always only see a square ad (although I choose a different ad ( 728×90 ad 300×600) but the same problem
thank you
Hello !
Pleas make sure that you have selected the auto-ads from google adsense: https://support.google.com/adsense/answer/7480616?hl=en
Those ads are automatically change size and format depending on what element they are installed in.
Thank you for your reply
But I set the size (as i want it)
Why does it change automatically? And it changes to square (300×250)
Although I do not chose this size
Please i need help
thnx
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
