problem with additional text being added to JS code that cause it to break
Hi guys,
Im trying to add a simple js tag to the section of Google analytics and js code section in the theme options.
however when I paste the tag, on the site itself I get this text being added to the tag:
type=”50e177f34662e44a4c4a365e-text/javascript”
the orignial tag looks like this:
<script src=’https://www.googletagservices.com/tag/js/gpt.js’&gt;
googletag.pubads().definePassback(‘/90155224/smartereum.com/1×1′, [1, 1]).display();
</script>
the problematic tag with the additional text:
<script src=’https://www.googletagservices.com/tag/js/gpt.js&#8217; type=”50e177f34662e44a4c4a365e-text/javascript”>
googletag.pubads().definePassback(‘/90155224/smartereum.com/1×1’, [1, 1]).display();
</script>
How do I avoid this part
Please make sure that you set the code exactly like in example:
https://www.screencast.com/t/5vvPpmuUpe
Hi Calin,
it was pasted exactly like you said, with our js code, which you can see at the original post. but this keeps being adding up !!!
you cann see here: view-source:https://smartereum.com/41795/xrp-recovering-xrp-price-analysis-nov-13/
this is how it suppose to look like:
<script src=’https://www.googletagservices.com/tag/js/gpt.js’>
</script>
but this is how it appears:
<script src=’https://www.googletagservices.com/tag/js/gpt.js’ type=”50e177f34662e44a4c4a365e-text/javascript”>
</script>
Please take a look and answer how to solve this. it is urgent
I’ve inspect your source page and is look like something set the type= in all scripts https://www.screencast.com/t/WBhxpsgi6Dr
https://www.screencast.com/t/iKqpekjT
This problem is not from Google analytics , please try to deactivate all plugins, clear all caches and try to see if the problem is still there, is possible to be a plugin conflict.
