Problem with ads section in the Theme panel
I updated WP to 5.8.1 and now i can not expand the ad settings for each positions, only the last one “Background click Ad”
What’s wrong and what can i do.
Andre
Hello Andre!
If your settings from the theme panel are missing and you use default templates, then please make sure you have Standard pack plugin installed and active.
Hi Betina
Standard pack plugin? where should that be?
I have the “tagDiv Composer” and i use the Default template.
As you see in the screenshot it will not expand the header ad settings.
null
This should work well. Check in the Newspaper -> Plugins.
The issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
