Hello there, I am trying to put adsense code into various boxes via theme panel/ADS, but when I paste the code and press Save settings, I get only eternal loading and nothing is happening. This actually happen with some other changes I want to make in Theme panel. Some work, some don’t at all. Could you please give me advice what to do?
Please check if you have this issue after you disable all plugins, leave only Visual Composer active, also empty cache. If you don’t have this issue anymore activate your plugins one by one and see which cause this issue.
Let me know how it goes.
Hi Alin, thank you for your help. It worked, however when I enabled again all the plugins, it is still working:).
I was able to put the codes in and save it, but I cannot see the ads on the website (header, sidebar and below article). Could you maybe navigate me where the problem can be?
I have checked your site and found these errors in console – http://screencast.com/t/DYrNvH7eCaA
Your ads seems to be blocked. This troubleshooter could also help: https://support.google.com/adsense/answer/1208336?hl=en
