I created an archive template for a specific Custom Post Type.
The standard pagination (numbers with links) works correctly… the different types of Ajax pagination (including infinite scroll) instead generate unexpected results (they ignore the filter on the specific Custom Post Type).
N.B. I installed the Query Monitor plugin which reports several PHP Warnings.
I specified only the postType.
When the page loads the contents that appear are correct, when scrolling (when the Ajax pagination takes over) unexpected results come out.
https://snipboard.io/Hhr2JZ.jpg
