Problem with alignment on desktop and mobile
Hello, first time using this theme, but not first time using visual composer.
When trying to set up 2 columns using visual composer, the block in the second column, automatically gets placed under the first one, not allowing me to properly set up 2 columns side by side.
Also, everything on the page seems to be shifted right and not properly centered as in the example files.
My domain is edmbangers.com , please let me know what I can do to fix this, thank you so much.
The theme blocks work fine on 3/3, 2/3 and 1/3 columns – http://screencast.com/t/j1iFmkZUc
If you added any custom css or code check it for errors.
Also try to disable all plugins except for Visual Composer and see if the issue is still there.
