Problem with AMP
hello I contact you for a problem with the plugin amp.
after installing your update 9.6 and after following your guide on how to best use my site to many problems …
1) charge more slowly.
2) I do not get scripts loaded and the site is very bad
How can I solve the problem? because if I’m not forced to downgrade
This is my site https://www.cybeout.it
I saw that trying to validate the page with the button on the admin bar there are many errors caused completely by Newspapar … and I repeat all !!
I’m forced to downgrade this problem because otherwise Google no longer indexes my pages in amp … waiting for your answers
For don’t applicate the downgrade on version 9.5, i’m install the another plugin and now i can normal use AMP…waiting for your answers
What AMP plugin are you using Daniel?
I tried two and the site crashed on activation
Now i’m use AMP for WP – Accelerated Mobile Pages. It is very simple to use. the important thing is that as soon as you have activated this plugin, do not activate tagdiv’s AMP and do not activate the theme setting function because the site is blocked
Mobile Theme: Automatic Optimization for Mobile with Newspaper Theme -> https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
How to Make an AMP ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/
Please make sure that you activate the amp from mobile theme -> https://www.screencast.com/t/6m5bxthx8ec and you check the box from general Amp -> https://www.screencast.com/t/WEyXhNzY
For this error https://prnt.sc/mupdgl here is the fix.
You’ll need to go in wp-content/plugins/td-mobile-plugin/td-mobile-plugin.php
and at the bottom of file set this code
$theme_options = get_option( 'td_011' );
https://prnt.sc/mv165e
https://www.screencast.com/t/NclX3sIf
Relented topic -> https://forum.tagdiv.com/topic/errors-after-update-2/
Also is not need to use the mobile theme with amp, you can sample use others amp plugins and use the responsive version of theme.
As soon as I have time, I try and hope it works.
Unfortunately I need to use the mobile theme and an amp plugin because Google has lately given me so many problems to index the pages
Hi @danielsandj,
Let us know how it works!
