Problem with analytics
The analytics is not showing the results on my article pages. This is a built in newspaper feature right?
Could you please log in and see what is the problem?
Screenshot: https://snag.gy/7RYeyE.jpg
Thanks, in advance,
Sincerely,
Please verify if your analytics code is added properly in head section. I suppose you use the analytics spot from Theme Panel, please verify you page source and see if the code is added there.
Also you can add the tracking code directly in the theme’s code if you think that it will help – https://support.google.com/analytics/answer/1008080?hl=enhttp://screencast.com/t/bcDItHOO1
Hello Alin,
The analytics code and also the google tags has been added properly to the theme header.
Whats next?
Please contact us via email at contact@tagdiv.com and provide wp-admin so we can login and investigate.
Okay, I sent the credentials,
sincerely,
I have the same problem. I downloaded the google analytics plugin. When I enter the code in the Theme Panel, the code begins to appear in the left-hand header. I do not know what else to do.
I’m waiting for some help.
The code comes from an incorrect implementation of the google analytics code.
The Analytics code needs to be added between the script tags like so:
<script>your analytics code</script>
