problem with apache mod PageSpeed and style.css
if the active form PageSpeed apache, the theme does not work, it’s as if it does not work style so the file style.css
help? thank you
theme works fine with mod_pagespeed …
you just need to setup a proper config file either at server level with dedicated box, or by manually specifying in htaccess file what to turn on explicitly — for example I found that CSS and JS minification does not work well — so it’s a “tuning” process for what is compatible with WordPress and what is not, a bit by trial and error, and also see my posts on this topic the past 18 months in forum as I have used it on our server since Jan. 2014 with TagDiv themes.
e.g.,
<IfModule pagespeed_module>
ModPagespeed on
ModPagespeedEnableFilters collapse_whitespace
ModPagespeedEnableFilters remove_comments
ModPagespeedEnableFilters rewrite_images
ModPagespeedEnableFilters insert_dns_prefetch
</IfModule>
see the docs for mod_pagespeed on which settings you may wish to activate other than the default “safe” batch of MPS settings.
  • This reply was modified 10 years by simchris.
