Problem with Archives widget
When I use this widget:
http://take.ms/uuUH9
It looks like this:
http://take.ms/P9oyc
So the name is duplicated somehow. Can you help?
Yeah… some funky bug in the latest version of WordPress for both the archives and the category widget … team effort — there was fix posted last week on this …. don’t have link handy …
tagdiv provided fix for categories and I added fix for archives …
oh wait, I can just look at my custom css (duH!)….
and the magic secret sauce is:
.widget_categories label {
display: none;
.widget_archive label {
display: none;
the duplicate title appears in all themes — not just tagdiv, as I noticed the same issue on couple of my older sites too. Annoying they didn’t catch that in WP 4.2.x.
Thanks Chris!
@securerr Please try custom css that Christopher suggested – http://screencast.com/t/rt0gYE1LOE
Hello Chris and Alin,
Thanks for help! It worked like a charm.
I think it would be great if you add little things like this to your documentation.
Alex
Not really worth it since it’s a temporary bug in WordPress – introduced with v 4.2x – nothing related to theme.
Hopefully WordPress will catch this and fix it in the next update.
