Problem with ARTICLE INLINE AD
There is a problem with Article Inline Ad. If used not formatted text in article, the AD unit displays. If the article uses the format (such as <p align=”justify” … ), the unit is not displayed. In the site uses formatted text, after update from nevspaper 4.6.3 to 6.1 that module is not displayed. Need HELP.
Yes, I’ve just checked it and the inline ad conditional has been changed and unfortunately the fix for the inline ad wasn’t included in the latest theme update.
I’ve added this on our todo list and implement the fix in the next theme version.
You can try not to use inline style until we fix this. We’re very sorry for the inconvenience caused.
Thanks for reporting this!
I have the same problem, i’ll wait the update 🙁
