Problem with Article Inline Ads
I am having a problem regarding Article inline ads. I am using a cloud template for a single post. While using Google Adsense ads on Article Inline 2 and 3 after certain paragraph but Google Adsense coming at the begging of the post. Article Inline Ads 1 and Content bottom is working as usual.
The Google Console Problem Link – https://drive.google.com/file/d/177kxY3DYIC57-n2-NBFrUb8HHv5hoRpp/view?usp=sharing
Screenshot of the problem – https://drive.google.com/file/d/1ILIRJyPAVwqcup5tqMu9iQ8Q-EagfSV3/view?usp=sharing
If you use a cloud/PRO template, then you should add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS.
For a default template you should add the ads in theme panel.
If you set up correctly, and the problem is still there, then the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Yes, I know that ads must be set inside the cloud template using tagDiv composer. I have already tried that but no luck. Again I have disabled all the plugins except the tagDiv, but still no luck. So I have already mailed with all the necessary credentials. Please check and help to solve the problem. Thank you and kind regards.
If you sent an email, then my colleagues will reply you as soon as possible.
Bonjour,
J’ai le même problème, avez vous trouvé une solution ?
Hi @vivreausmic!
Please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate your issue too. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
