Hi, I noticed that on my site http://www.zawszenawakacjach.pl my author box changed its look, text used to be wide and now its on the left side and also it used to be on the same level as photo and now its a bid lower.Also the next and previous post buttons fonts changed.Can you tell me what could caused this change and how I can fix it .
Hello fxnewsman,
As you can see, our default theme work as properly, as you can see in our demo, like this -> https://www.screencast.com/t/Sn96SaMf I suppose that your changes happen due to your untested plugins which are used on your website. Please try to revert the theme to the default state, remove all untested plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins.
