Good afternoon,
I have a problem. I can’t see the Author page…If you go to any Author Card and click on the name takes me to the homepage. What it could be happening?
I’d like to use a template from your Cloud Templates…but firstable I must find a solution for my problem.
Do you have any tutorial about how to set up an author page from your library?
If this dos not do it, please also try to disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Thanks! Not it works!
By the way, it would be fantastic if you could create a customized Author Page by author. Is it possible?
Hello Antonio,
In the near future update, we will include an option that allows you to add a different author template for each author. At the moment, you have a single author template for all of your authors. If is not what you mean, please provide more details so I will be able to provide a more accurate response.
It’s exactly what I meant before! Thanks for your support!
