Problem with author-template-6
We have a problem with “Author template 6”. There is no possibility to change the author’s name. After a couple of reinstallations, I decided to write to you.
I also include a photo:
https://imgur.com/a/3tjWmTJ
Regards
If you referee at “Sample Author name”, the name of that box appear only in template editor, after you’ll set the template on author will look like this: https://www.screencast.com/t/BeRKKMzuBtDe , admin is an author.
