Problem with Avatar Plugin
Hello, I have installed a plugin to change the default WordPress avatars by other random (Rage Avatar). The problem is that since I installed the Newspaper theme, these avatars are not displayed (in the WordPress editor yes, but not in the theme).
The plugin is this:
https://wordpress.org/plugins/rage-avatars/
Any solution?
Unfortunately i can’t give you an accurate answer as the theme wasn’t tested with Rage Avatars so it’s a possibility to appear some issues. You can contact the plugin writer and ask for advice, but in the meantime please check this links, maybe you will find an useful information:
https://wordpress.org/support/topic/plugin-rage-avatars-avatars-not-showing
https://wordpress.org/support/topic/rage-avatars-does-not-work-gravatar-problem
Notice that we recommend https://wordpress.org/plugins/wp-user-avatar/ as avatar plugin.
