Problem with background ads
Hi, I bought the template newsmag 4 but I have a problem with the image for the background ads.
I followed the instructions on the documentation but the no stretched image is placed above the top header. How can I solve? the affiliate link instead runs regularly
Thank you
http://lnx.aereidaguerra.net/foto4go/
for example i need to have this result https://labussolanews.com/
You can indeed set a background image and a link for it. I see you have currently set a thumbnail image, please make sure you set it in full size for better results
https://www.screencast.com/t/5KeOsSjlf9
https://www.screencast.com/t/Q7jIPljCDrlv
If you want to create a space above the website, so that the ad is displayed there as well, similar to the website you mention, enter this code in the advanced custom CSS->desktop section
https://www.screencast.com/t/0wUxLtLrx9F5
Result – https://www.screencast.com/t/MlR3CN0hBPr
.td-header-wrap {
margin-top: 115px;
Please let us know if you have more questions.
Thanks for your help! I had not seen the setting in the mask for the upload!
Can I ask you how is it possible to make the link ref active on all the background and not only on the sides?
Emanuele
Try it like this instead, should be able to click in the top space after adding this code
.td-header-wrap {
padding-top: 115px;
.td-ad-background-link .td-header-container {
cursor: pointer;
Remove the previous code and enter the one above.
