Problem with background in categories
When in the Themes panel categories options I choose BACKGROUND COLOR (any color) reduce the width of my post article on the desktop version of the web. I noticed this in the sports category where I had chosen the color green.
Hello !
That will happen when setting a background color. Newspaper theme has been built so that when you upload a background color or image it will shrink the width of your website. If you are running cloud library templates you will be able to set the ROW background using tagDiv composer as you can see here: https://www.screencast.com/t/7riwya30L
where the text of the article is I want a white background, and behind the margins I want the color of the category itself. That is, I want each category to have a different color and to use the option through the options in the theme itself, which is offered, but without narrowing the web.I didn’t have this problem before the update
Hello !
On tagDiv Composer this can be done by setting a background color to your row, you will have to set a border that has the same color as your background: https://www.screencast.com/t/4H5WZNr0
And you will have to click on the zone: https://www.screencast.com/t/ZxuNDgCkd and set its background color: https://www.screencast.com/t/ZxuNDgCkd
