problem with background
hellow,
i have set an an imaga as a background for my website. ia have noticed that the background creates problem in the mobile verion of the website. Why is this happening? can the background be viewable only from pcs?
thank you in advance
The theme doesn’t display the background image on mobile devices, as was designed with a full width layout. To change that you will need custom modification in theme’s core files and if you don’t know how to do it yourself my advice is to look for a developer from sites like: http://studio.envato.com/ to do it for you, as we cannot offer any custom work at this moment, sorry.
i am not asking for a custom modification. iam telling that when i see the website from a mobile device (ipad,iphone) the background is like “flashing” in the center of the page when i scroll down.
Please provide your site url so I can inspect this issue closer.
hi
sorry for the late answer. the website is still under construction i have made it “viewable” for a few minutes to do some tests and i have noticed the problems
If the site is not live yet, you can make some screenshots which highlights this issue so I can duplicate it on my side, so I can provide a more accurate answer.
My website is viwable. I browse from ipad and iphone and i think that the background creates problems. Please check it out ( runnersclub.gr) thank you
I’ve checked your site on iPod and the content seams to be displayed fine now: http://screencast.com/t/L32f62Vb – http://screencast.com/t/mMpjGDMBF If you still have this issue try to clear the iPad/iPhone cache memory, deactivate all plugins except Visual Composer and test again. If the problem persist please provide a screenshot and a specific link so I can inspect it closer.
please check the scroll down the theme does not load well
try to visit also thw website from an android phone. the images does not load
from an naother android phone the images are shown but some letters are not shown and instead of them there is a square in the text. What is going on with your mobile theme?
Please provide some images pointing the issues, also a specific link, as I can’t find them on your website. On my side the site loads fine: http://screencast.com/t/KAm8oSKY – http://screencast.com/t/96V9gvZpE8
check and this also please. http://www.screencast.com/t/7sRwyM5RzCNH
i scroll down from ipad and when i scroll up the main menu bar is completely missing.
please provide a solution as soon as possible.
the problem with the menu bar at the ipad is because of the sticky menu. when you deactivate the sticky menu is ok.How i can fix this. what about the problems with the mobile version?
Please make sure that you set the the smart snap to be always displayed: http://screencast.com/t/GBer6k6r4
Regarding the issues with images on mobile I am not sure why this happens as I’ve tested your site on mobile devices and works fine: http://screencast.com/t/GBer6k6r4 Try do deactivate lazy load animation, clear all caches including the phone’s cache, deactivate all plugins except Visual Composer, and test again.
Viewing 16 posts - 1 through 16 (of 16 total)
