Problem with basic editing of pages on site.
Hello, I just purchased this theme and am trying to make changes to the home page (default Newspaper). I couldn’t simply delete two empty columns that were there with the Visual TD Composer. So I was thinking it would be straightforward to go into the page editor and edit the content directly. Boy was I wrong, the editing is horrible and the markup is not formatted in any way from the demo!
I wish I could share a screen shot but the shortcodes are all jumbled together and not only that wordpress minimizes the width of the page editor. I will have to copy and paste the text of the default newspaper homepage to another editor so I can make sense of it, make the changes, and then paste it back when done. How come the default demo content is so unstructured and all garbled together on what looks like one line? And also how come I can not do something as simple as delete an empty column in TD Composer? This is supposed to be easy and this is anything but to do the most basic editing!
Well, you can. Please do not edit the code by hand. It is so to discourage hand editing. Any modification must be done from the tagdiv composer only. In order to remove a column altogether, you have to change the column layout from the row settings: https://www.screencast.com/t/NAcMOqH122SO
I have the same issue, I want to use Visual Composer to edit this site, as I find the TagDiv very frustrating.
Can this demo code be rendered editable with Visual Composer?
Hello !
No, Newspaper Theme has been created using tagDiv composer. Unfortunately WpBakery will not work on TagDiv Composer templates.
