Problem with bbpress background field colour and search bar
I am uisng bbpress in my website.
http://naadal.com/forums/
I have two issues now:
1) Search bar not appearing properly.
2) Background field colour problem (It appears in white colour and content headings are not visible properly).
It seems none of the theme styling for bbpress is applying. A suggestion that you could try would be to deactivate all other plugins except theme plugins and bbpress and clear any installed caching. Then check if the forum page is displaying properly.
I could give you a code to fix these two issues, but there might be others at a later time
– https://www.screencast.com/t/ccuh8QXGchiW
The theme will use it’s own styling for the bbpress elements, but they are not applying here. It could be the optimization plugin or a maybe a different one that is casing the issue. Try what is mentioned above and check the results.
