Hi all,
I have a serious problem with NewsMag theme that I’m using in my site togheter with bbpress forum.
This is the problem: when user try to login or register to fourm, by clicking on “Log in /register” at the end of the page, it appears a black screen without any possibility to do something..
so for example, here:
http://analisidelsangue.net/forums/topic/ves-41/ if you try to click on “Log in /register” at the end of the page you can see the problem…
As someone of your staff suggested me, I tried to turn off all plugin of my site to avoid any conflict between plugin and newsmag theme.
To be sure of this, I had deployed a copy of my site on amazon Ec2 .. here
http://ec2-54-155-7-225.eu-west-1.compute.amazonaws.com/forums/topic/ves-41/
but as you can see the problem there is in this site too (without plugin)
So peraphs this is a dimostration that the problem is between Newsmag theme and bbpress forum
Can someone help me about this point?
thank you very much for your help
alessandro from Italia
I would but I am not having issues on my end at all with it on my website. So I would help if I could and I don’t think it is the theme since I am not having the problem at all. http://www.awesomebryner.com/forums/ and see for yourself.
Hi @cmistico
I’ve checked your site and noticed that the login widget is deactivated, that’s why appear that black screen: http://screencast.com/t/XQ7sLyT27Q Try to enable the Sign In/Log In options from theme panel > top bar: http://screencast.com/t/ExAiXz8SYxO and test again.
Andrei L..
I have exactly the same problem on my bbpress forum but running on Newspaper, just noticed this a few days ago. My settings are ok and was working fine before.
