Problem with big grid
Hi, i have a problem with my big grid adter updating. This is what i see on my editing page
one
And this is what i get on Internet
2
  • This topic was modified 5 years by Zarten.
Please do these steps
1. disable all tagDiv plugins
2. uninstall all tagDiv plugins
4. re-install all tagDiv plugins again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate all tagDiv plugins
Also, make sure your WordPress and plugins are up to date.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
Hi! Ok, there is a plugin conflict, but it is new, there wasn’t such conflict before updating
The plugin is Schema App Structured Data in its latest version, 1.17.5
it is known? are you going to correct it? thanks
Unfortunately, this plugin is not a tested one with our theme.
Thank you for understanding!
