Problem with Big Grid
First of all: Great theme!
Maybe the answer to my question is simple but i´m a new user of this theme and i´ve found no answers in the forum.
I changed my site to the Newspaper theme and now i´ve a problem.
I tried to use a Big Grid Element on the new page (using Visual Composer) but if i use it – the result is like you can see on the picture – this happens with every Big Grid i use – there´s ever an element to much.
Example Picture
OK, after trying more and more – the problem affects more parts.
Whatever i choose – a Big Grid or a Block – always 6 elements will be shown. The settings of the Block to show only 4 Articles will be ignored.
This affects a lot of parts of the theme, and i don´t know where the failure is…
This may be caused by a featured post plugin. Our theme does not support featured posts in it’s modules and blocks so please try to disable all plugins except visual composer, clear cache and check again. If the problem is still there afterwards, please try to do a fresh install of the theme.
Let us known how it goes.
Alle Plug-Ins disabled, cache cleared and a fresh install of theme – et voila: It works!
Thank You!
