problem with big slide and small slide
Hi i have few problems on my website http://aktuelno24.mk/.
On my homepage i have issues with big slide and slide. Isn’t moving?
Why RT Facebook Like Box who is showing right in the corner is not closing ?
Why on chrome and opera main menu is black with white letters, but on mozzila is black with black letters?
Thanks in advance
You have some js errors in the console – http://screencast.com/t/nVcjM8aoQ Please disable all plugins except of Visual Composer, clear cache, purge your files if you use CDN and check if you still have this issue. Also try this without any css/js minifications.
I deactivated all plugins except visual composer. After that i had bigger problems. Main menu wasn’t mega menu and it wasn’t sticker menu. Letters on there were smaller. Show more and next-prev button wasn’t working. Tabs at the bottom of homepage was showed all. Big slide and slide still was not working. I reinstal Visual composer a update the theme, but the problem was still there.
When i start to activate plugins, all problems was there. When i activate them all, only two first problems was stil there, with big slide and slide. The others was fixed.
I don’t know what else to do. Please help?
Please send an email at contact@tagdiv.com and provide wp-access so we can take a look, also paste a link to this topic so we can know who you are. We will answer as soon as possible.
