Problem with 'Big Slide'
In the demo (http://demo.tagdiv.com/newspaper/homepage/) the big slide have one big images and the small images. I manage to create this, but, the problem is that the image for a post do not get big in the slider. I tried to use a big image in the post, but then the image got big in the post to.
Here is a image of the problem, I think you will se what I am talking about: http://www.flickr.com/photos/74534825@N07/10554922275/
What are the dimensions for your uploaded picture?
745×483 like in the demo.
the 745×483 image should work well on the slider and it should also be cut for the posts. If you have a dedicated server or vps … please make sure you have the gd library installed and appropriate permissions. It looks like wordpress can’t cut the images.
How do I do that?
Please open that post and see what image size you have as featured image.
To check if you have GD library installed follow the steps from here: http://www.websitecamp.com/check-php-gd-library-installed-or-not
also check if you have appropriate permission on the UPLOAD folder
