I’m expecting some issues regarding the big slider on my homepage as I don’t have always big images.
Example: http://blog.mister-chien.com/
Could you say me if there is an option to auto fit the width and height of the images ?
And how I m able to disable this big slider on the homepage ? I don’t find the option.
I have checked your site and found that you use a page template with big slide, that why you can’t disable it. Please use a template without Big Slider background – https://forum.tagdiv.com/page-templates/ and add Big Slider manually on pages where you need it: http://screencast.com/t/2zRf2U5s7Z
You have that issue with images because you use small featured image as WordPress cannot enlarge thumbnails, only make them smaller. You need to use a plugin like Thumbnail Upscale: https://wordpress.org/plugins/thumbnail-upscale/ to enlarge thumbnail. For upscale use a combination of plugins Thumbnail Upscale + Force Regenerate.
