I’m suddenly unable to click on the frontpage big slider. How can I find a solution ?
I’d like to add that I can click right but not left my home page is http://loirexplorer.com/.
Thanks by advance for your help.
This issue with the slider occurs because of Yoast Google Analytics plugin. We know about this and we are trying to fix this but unfortunately is more difficult than we initially tooth. You can disable this option from Yoast Google Analytics general settings, will fix the issue with the links: http://screencast.com/t/LRV9LlBn3 or you can also use our own Google analytics support (just paste the code in our admin): http://screencast.com/t/EtxOCuXlspj
