Problem with block 16
I’m using block 16 in my homepage but some thumbnails don’t display correctly.
I’ve tried even to resize the images but it doesn’t work.
https://anonymster.com Here you can see that the thumbnail for ExpressVPN review is oversized.
How can I fix that?
It should be taken in consideration that modules use different thumbs with different aspect ratio’s, each block uses a specific thumb which crops the featured image from your posts. The theme uses the system of cropping from center to top and uses a WordPress function add_image_size – https://developer.wordpress.org/reference/functions/add_image_size/
More about this here – https://forum.tagdiv.com/thumbnails-vs-featured-image-size/ also how the cropping works – https://forum.tagdiv.com/api-thumbnail-introduction/
