Problem with block element
Since the latest update the block elements that I have used don’t work properly. In the CMS I see the grid exactly how it has to be, but the site itself shows only images in a long vertical row. See here at the bottom of the homepage: https://schooldomein.nl. Please help! Thanks!
It looks like a problem with visual composer. The problem is that it is set to be a column, but that is not reflected in the HTML.
Hello PaulVoogsgerd,
I have inspected your website and I saw that you have added a simple image to a text_column element which has 300px*186px as dimensions as you can see here -> https://www.screencast.com/t/Tg4r0XfR How would you like to show it to you? Try to use bigger images if you want to achieve other results.
If is not what you mean, please provide more details so I will be able to provide a more accurate response.
Hi Catalin,
Thanks for your support. But it´s not what I meant. The problem is that — I think since the latest update — de images which I placed in a grid (using block elements) are shown in a long vertical row. This is what it looks likes in the CMS: http://www.schooldomein.nl/wp-content/uploads/2018/01/backend.jpg.
But the site shows this: http://www.schooldomein.nl/wp-content/uploads/2018/01/frontend.jpg.
I made no changes except for the latest Newsmag update.
I hope you can help me with this. Thanks again!
Hello Paul,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this topic so we can quickly identify you.
Hello Catalin,
I just did. Thanks for tour help!
