Problem with block settings and ajax
Hello to you all. Recently i decided to go with my own website and went with newspaper 8 theme. I’m still learning the possibilities of the theme but i’m stuck with this problem and i can not find a answer on this forum neither on net.
So, the problem is following, I’m trying to build a block with content from multiple categories and when i dedicate those category in ajax search i do not get links on the menu in the right upper side of the box. Whatever i try i only get links to All pasts and posts from one category(In this particular example, Recipes). Can anyone more experienced help me with this issue.
Thank you,
Milan
Problem with blocks content and ajax
  • This reply was modified 9 years by Arioth.
Thank you for choosing the Newspaper theme for your website. We always try to help and provide solutions as soon as possible, here on the forum.
As a first step please make sure the category ID’s that you enter in the filter are correct. Then make sure those categories have posts assigned to them. Categories without posts will not be displayed in the filter.
Please let us know if there still is a problem.
Thank you for the reply. I found that solution deep in the night but forgot to write here. Anyway, thank you again.
