problem with block1
hi,
i have a website that is under construction. I use the block 1 mode to show some posts in the home page. i have visit my from a chrome broswer running in a windows 8 pc and i realized that the block was not shown well. the 4 posts were not next to the latest but under it.why is tgis happening?
Thank you in advance
If you have a similar layout with this one: http://screencast.com/t/aiPwJI5rq that happens when the block it’s used into a 1/3 colon: http://screencast.com/t/7v82gUGyqQ so please make sure that you’re using at least a 2/3 layout: http://screencast.com/t/TmSEbfe6UfL
If this does not help please provide a screen pointing the issue and more specific details so I can duplicate it on my side.
thank you for your answer yes i use a 2/3 layout as you can see here http://www.screencast.com/t/4M19PtlJ9
i see it normal from my pc but yesterday i visited the website from a chrome broswer running at windows 8 and i saw this http://www.screencast.com/t/32WVzctMxLme
from my pc i see this http://www.screencast.com/t/iHoFzjeIvme
The theme is tested and works fine on Google Chrome. I am not sure why you seen a different layout, but I suspect there was a margin or something else which shouldn’t be there: http://screencast.com/t/YleE2KwQmt If you still have this issue please provide a screen from Visual Composer page builder or the code from Backend Editor via http://pastebin.com/ so I can duplicate the situation on my side.
http://screencast.com/t/YleE2KwQmt this is just the background image of the website!!
http://www.screencast.com/t/ajmwhkqnx26 screen from page builder
The block should be displayed fine with this layout, so if you still have this issue please make sure that the browser zoom settings are on default values, otherwise the layout may be affected: http://screencast.com/t/f7HfjUhRH
