Problem with Blockchain template on iOS mobile
Hi there
I have a problem with the home page of the Blockchain theme I have installed, on any mobile browser on iPhone.
The issue is present also on the demo (https://demo.tagdiv.com/newspaper_blockchain_pro/)
When the page is loaded part of the hero section does not appear.
When it is scrolled down, the hero section appears, but the upper part is cut (the label “invest in crypto the smart way” is not visible).
Any suggestion on how to fix this?
Vittorio
Hello Vittorio!
Please edit the homepage with the TagDiv Composer, select the mobile viewport and uncheck this setting from the top inner row: https://prnt.sc/DzfRJuf4iVcY
Save and view the results!
Thank you Bettina. I’ve followed your instruction but now the mobile browser shows a very big empty space before the inner row. How can I reduce it?
https:prnt.sc/flYgDZ0ODPI8
Please check also, the padding on the element Raw Html -> https://i.imgur.com/P4DT6IJ.png set other value.
